Create Design Points
On each design point set, you can access the Auto DDP option available in the
context menu. Auto DDP provides a set of options to
create design points.
- A selector to reduce detection area
- Options for pattern detection
- Options for structural property to create and assign (if any)
Click OK.
An algorithm detects patterns and generates a collection of design points inside the parent design point set. Depending on the options it also creates and assigns structural properties. Auto DDP always creates new design points inside a design point set, no matter what already exist in the database. This allows you to have multiple design points at the same location but different structural properties.
Figure 1. (Rivet) Auto DDP
