Create node-to-node CBUSH elements at the connector locations point/node or
line.
Restriction: Only available in the OptiStruct and Nastran user
profiles.
From the menu bar, click .
When using fastener setup, the nodes need to be opposite of each other when two
plates are connected (congruent meshes). If the meshes are not congruent, it is
recommended to use RBE3-CBUSH-RBE3 or CFAST connector types.
Note: You must provide
the rivet diameter, or you should have axillary lines to represent the
diameter.
