Perform Manual Refinement
Use the Refine: Manual tool to refine elements manually.
Refine: Manual Tool
An overview of the Refine: Manual tool.
Figure 3.
- Access
- Go to .
Options
- Adjacent element layers
- Set the number of adjacent element layers to auto-select.
- Edge split count
- Set the number of times each edge of the selected entities is split. A higher value means a more aggressive refinement. This can only be modified when nothing is selected.
- Split patterns
- Set the patterns used for different element configurations and edge split scenarios.
- Smooth number of layers
- Set the number of adjacent element layers to smooth.
