Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Review the selected Part Assembly/Part in HyperWorks
graphics.
This review function uses parallel processing and is used in case of huge number of
selected part and it takes time in normal import operation.
Once the model is displayed in the graphics, you can select unwanted parts in the
graphics and delete them; simultaneously, the Part Browser gets
updated.
Note: The number CPU set in the configuration general section is used
for parallel processing.
It is recommended to use this function before CAD Intersection or Comparison is
executed for full car model where it is not sure the parts are in right
position. Figure 1. Intersection Check on Each CPU
Right-click in the Verification/Comparison Browser and select Review
Results from the context menu.
