Configure Browsers
Change the display and behavior of browsers.
Note: Not all browsers can be configured.
- Right-click in a browser and select Configure Browser from the context menu.
Edit any local options.
Local options are specific to a browser and a solver interface. To configure global browser options that are common across all interfaces, go to File > Preferences > Browsers.
- If available, use the Entities tab to select the entity types that are displayed in the browser.
Click one of the command buttons to close the dialog.
- Click Apply to append the new settings without closing the window.
- Click OK to keep the new settings, including those that are not applied, and close the window.
- Click Cancel to discard the changes that are not applied (keeping previous applied settings) and close the window.
To change the columns/attributes that display in a browser, right-click on a column heading and toggle
checkboxes in the microdialog.
Figure 1. Attribute Configuration Options for the Model Browser
