Required model files are available online on the Altair Connect website.
1. | Go to Altair Connect. If documentation is installed locally, you can find model files as follows: |
| Windows example: C:\Program Files\Altair\2020\tutorials |
| Linux example: \2020\Altair\tutorials |
2. | If required, enter your user ID and password. |
If logging into Connect for the first time, click Sign up for Altair Connect and use the New Account page to sign up for a Connect account. Follow additional instructions on the Altair Connect website to obtain your login credentials.
3. | Hover over HyperWorks Suite or your desired product from the Standalone Products section of the page. Right-click and select Documentation. |
4. | Select the suite version from the list, then in the Documentation tab, scroll to find the Tutorial File section and select the desired tutorial model files to download. |
Note: The files may require unzipping before proceeding with the tutorials. When extracting zipped files, preserve any directory structure included in the file package.
