The AutoReboundStop entity limits the movement of the suspension while in rebound or extension by applying a line of sight
force between two components when their distance exceeds a specified value.
AutoBumpStop
The AutoBumpStop entity restricts the movement of the suspension while in bump, or jounce, by applying a force between two parts.
AutoReboundStop
The AutoReboundStop entity limits the movement of the suspension while in rebound or extension by applying a line of sight force between two components when their distance exceeds a specified value.
