Get Started
On Windows, use the
On Linux, use the following command in a command shell:
~altair_install/altair/scripts/mview
Note:Where,
~altair_install
is the path where Altair HyperWorks is installed.
User Interface
The user interface provides you with a consistent look and feel when you are working in MotionView or any of the HyperWorks Desktop applications.
- Title Bar. Indicates which product is active. Because you can switch between clients, clicking on and activating a different window may change the information in the title bar.
- Menu Bar. Contains pull-down menus that provide access to standard functions such as New, Open, Save and Undo/Redo. This is also where you can access system preferences, and the help.
- Toolbars. Group of icon buttons that provide access to common tools.
- Tabs. Contains browsers, Utility menus, and other functionality not shown in the panel area.
- Modeling Window. Displays your model and plots, and allows you to select entities and manipulate the view of the model in the modeling window.
- Page Display and Navigation Area. Displays the page number that is currently on display and the total number of pages, and allows you to navigate between pages.
- Browsers. Displays view-related functionality in MotionView by listing the parts of a model in a tabular and/or tree-based format, and provides controls inside the table that allow you to alter the display of model parts.
- Command Window. Enter and execute Tcl/Tk commands.
- Panels. Displays pre-processing and post-processing tools.
- Status Bar. Displays information pertaining to the currently loaded model as well as descriptions of the pages and panels.
See the User Interface topic in the HyperWorks Desktop Overview help for more information about the different areas of the HyperWorks Desktop interface.
A multibody system study generally involves the following broad steps. The following sections give a brief introduction to using MotionView and the related HyperWorks products to conduct such a study.
