Air springs are commonly used in trucks, buses, and rail vehicles because their internal air pressure can be increased
or decreased to adjust for the load carried while maintaining ride height.
The Spring carries the vertical load in a suspension, keeps the tire in contact with the road, and absorbs energy from
road irregularities that would otherwise be transmitted to the vehicle and passengers.
AutoAirSpring
Air springs are commonly used in trucks, buses, and rail vehicles because their internal air pressure can be increased or decreased to adjust for the load carried while maintaining ride height.
AutoSpring
The Spring carries the vertical load in a suspension, keeps the tire in contact with the road, and absorbs energy from road irregularities that would otherwise be transmitted to the vehicle and passengers.
