Closed Loop Controllers
Closed-loop controllers use vehicle responses (for example, speed, position, yaw rate, etc.) as feedback to determine the vehicle inputs needed to match a desired vehicle response, such as following a path.
Closed loop controllers typically compute the error between a desired response and the actual vehicle response and use the error to calculate the vehicle inputs. Each vehicle input (driver output) can employ one or more closed loop controllers during a maneuver.
Use Cases
- Follow a path
- Follow a velocity/acceleration profile
- Follow a racing line for multiple laps
- Throttle and Brake Controllers
- Feedforward Traction Controller
- Feedback Traction Controller - PID Controller
- Steering Controllers
- Feedforward Steering Controller
- Gear and Clutch Controllers
- Engine Speed Controller
- Additional Controllers
- Feedback Controller
