Additional Parameters for the MF1989 Variant
The following is a list of parameters which are common to all Magic Formula 1989 variant.
Section [LATERAL_COEFFICIENTS]
This section specifies the MF 89 side force parameters for purely lateral slip:
Name in input file Unit Required Default value Explanation
a0 .. a13 - Yes - a0 to a13
Section [LONGITUDINAL_COEFFICIENTS]
This section specifies the MF 89 longitudinal force parameters for purely longitudinal slip:
b0 .. b10 - Yes - b0 to b10
Section [ALIGNING_COEFFICIENTS]
This section specifies the MF 89 aligning torque parameters for purely lateral slip:
c0 .. c17 - Yes - c0 to c17
