Import Geometry
- From the File menu, select Import > Geometry to display the Import Geometry dialog.
- Select the Parent system into which the CAD has to be imported.
Select the importing CAD file using the File
selector.
MotionView will read the CAD and the components and display in the table. It will also identify the length unit that the CAD was built in (if that information is available).
Figure 1. -
Change the material of any component if needed.
- Select the check box from the first column in the table across the component(s). The selector/deselector can be used to select All/Select None/Flip Selection.
- Click on the MaterialProperty collector and select the appropriate material.
- Click Set.
- Activate the Create one Graphic per component check box to create one graphic for each component.
- Activate the Create a new Body for each Graphic check box to create a new body for each graphic.
- Activate the Import Wireframe Geometry check box to import the wireframe geometry.
- Review the Component and Mass information and click OK.
