Assembly Wizard Changes
Model type – new options “Full vehicle with advanced
driver”.
Figure 1. -
Primary systems for full vehicle with advanced driver model.
Powertrain:
- Manual transmission
- IC Engine Friction Clutch Powertrain.
- Linear Torque Map Powertrain
- Engine that applies torque directly proportional to driver throttle output.
Driver Signal Generator: Five solver variables which provide and
interface to link user defined signals to the driver.
Powertrain:
Select a driveline system.
Disk brakes: Apply braking torque on the wheel joint proportional to
the driver brake output.
Figure 3.
