Auxiliary Posts
- Posts can be added or deleted using the ‘Add’ or ‘Delete’ buttons respectively.
- Attachments for each Auxiliary Post consist of Body and Point.Note:
- An orientation joint is used between the Jack Body and the ground.
- A ball joint is used between the Jack Body and the attachment Body.
- Signal Type - There are three signal types that can be used for the input to an
Auxiliary Post:
- Displacement
- Force/Moment
- Acceleration: Acceleration is first converted to displacement, following which the displacement is applied.
![](../../images/post_processing/npost_aux_post_panel_tab.png)
Figure 1. Auxiliary Post Functions and Options
