RMOD-K Supported Models, Road Surfaces and Operating Systems
Tire Models
- Rigid Belt Model (RFNRB)
- Flexible Belt Model (DMRB)
The tire models, their use, and the underlying assumptions behind them are described in the RMOD-K Users Manual available on their website (http://www.rmod-k.com).
Road Models
- Parametric Object Model - The parametric object model road describes the initial road surface and then allows you to describe a series of parametric objects on the road. Parametric objects include a spherical calotte, a cuboid with an optional chamfer, a triangle, and a cylinder.
- 3D Road Scan - This is a scanned road surface. A point cloud , a wavefront file, and a variety of other files can be used to generate road surface models from measured data. Road surfaces can be measured using a road profilometer.
Operating Systems
- Windows 32
