FVSA Lateral and Vertical Location
Request Number: 50000170
Component | Unit | Comment |
1 (X): Left Wheel FVSA Lateral Location | mm | The lateral distance between the left wheel center and the left wheel center
front view instant center or: length * cos(angle) See left wheel front view swing arm length and angle calculations in BranchID 160, components 1 and 4 (in Front View Swing Arm Length and Angle). |
2 (Y): Right Wheel FVSA Lateral Location | mm |
The lateral distance between the right wheel center and the right wheel center front view instant center or: length * cos(angle) See right wheel front view swing arm length and angle calculations in BranchID 160, components 2 and 5 (in Front View Swing Arm Length and Angle). |
3 (Z): Average FVSA Lateral Location | mm | The mean of components 1 and 2. |
4 (RX): Left Wheel FVSA Vertical Location | mm |
The vertical distance between the left wheel center and the left wheel center front view instant center or: length * sin(angle) See left wheel front view swing arm length and angle calculations in BranchID 160, components 1 and 4 (in Front View Swing Arm Length and Angle). |
5 (RY): Right Wheel FVSA Vertical Location | mm |
The vertical distance between the right wheel center and the right wheel center front view instant center or: length * sin(angle) See right wheel front view swing arm length and angle calculations in BranchID 160, components 2 and 5 (in Front View Swing Arm Length and Angle). |
6 (RZ): Average FVSA Vertical Location | mm | The mean of components 4 and 5. |
