Ideal Steer Angle
Request Number: 50000280
Component | Unit | Comment |
1 (X): Ideal Steer Angle | deg | The outside wheel steer angle required to produce a turn radius equal to the
turn radius produced by the inside wheel steer angle. It is calculated with the
following equations:
2 (Y): Not Used | Not Used | Not Used |
3 (Z): Not Used | Not Used | Not Used |
4 (RX): Not Used | Not Used | Not Used |
5 (RY): Not Used | Not Used | Not Used |
6 (RZ): Not Used | Not Used | Not Used |
