Ride Steer, Caster, and Camber
Branch ID: 180
Request Number: 50000180
Table 1.
Component Unit Comment
1 (X): Left Wheel Ride Steer deg/m The left wheel steer angle change due to in-phase vertical deflections of the left and right wheels or:
rtod*(C(6,3)+C(6,9))/(C(3,3)+C(3,9))*1000
2 (Y): Left Ride Caster deg/m The left caster angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
rtod*(C(5,3)+C(5,9))/(C(3,3)+C(3,9))*1000
Orientation B
rtod*(-C(5,3)-C(5,9))/(C(3,3)+C(3,9))*1000
3 (Z): Left Wheel Ride Camber deg/m
The left wheel camber angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
rtod*(C(4,3)+C(4,9))/(C(3,3)+C(3,9))*1000
Orientation B:
rtod*(-C(4,3)-C(4,9))/(C(3,3)+C(3,9))*1000
4 (RX): Right Wheel Ride Steer deg/m The right wheel steer angle change due to in-phase vertical deflections of the left and right wheels or:
rtod*(C(12,3)+C(12,9))/(C(9,3)+C(9,9))*1000
5 (RY): Right Ride Caster deg/m The right caster angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
rtod*(C(11,3)+C(11,9))/(C(9,3)+C(9,9))*1000
Orientation B:
rtod*(-C(11,3)-C(11,9))/(C(9,3)+C(9,9))*1000
6 (RZ): Right Wheel Ride Camber deg/m The right wheel camber angle change due to in-phase vertical deflections of the left and right wheels or:
Orientation A:
-rtod*(C(10,3)+C(10,9))/(C(9,3)+C(9,9))*1000
Orientation B:
