Roll Inclination
Request Number: 50000200
Component | Unit | Comment |
1 (X): Left Wheel Roll Inclination | % (deg/100 deg) | The left wheel camber angle change with respect to the true ground line (line
connecting tire patches) due to out-of-phase vertical deflections of the left and
right tire patch points expressed in degrees of axle roll
or: track = abs((right wheel center y) - (left wheel center y)) deltaz = C(3,3)-C(3,9)-C(9,3)+C(9,9)+2/(tire stiffness)
2 (Y): Right Wheel Roll Inclination | % (deg/100 deg) | The right wheel camber angle change with respect to the true ground line
(line connecting tire patches) due to out-of-phase vertical deflections of the
left and right tire patch points expressed in degrees of axle roll
3 (Z): Average Roll Inclination | % (deg/100 deg) | The mean of components 1 and 2. |
4 (RX): Not Used | Not Used | Not Used |
5 (RY): Not Used | Not Used | Not Used |
6 (RZ): Not Used | Not Used | Not Used |
