Spindle Length and Offset
Request Number: 50000270
Component | Unit | Comment |
1 (X): Left Spindle Length | mm | The true left spindle length or the distance between the left wheel center and the point on the spindle which is closest to the kingpin axis. |
2 (Y): Right Spindle Length | mm | The true right spindle length or the distance between the right wheel center and the point on the spindle which is closest to the kingpin axis. |
3 (Z): Average Spindle Length | mm | The mean of components 1 and 2. |
4 (RX): Left Spindle Offset | mm | The true left spindle offset or the minimum distance between the left spindle axis and the left kingpin axis. |
5 (RY): Right Spindle Offset | mm | The true right spindle offset or the minimum distance between the right spindle axis and the right kingpin axis. |
6 (RZ): Average Spindle Offset | mm | The mean of components 4 and 5. |
