SVSA Fore/Aft and Vertical Location
Request Number: 50000150
Component | Unit | Comment |
1 (X): Left Wheel SVSA Fore/Aft Location | mm | The longitudinal distance between the left wheel center and the left wheel
center side view instant center or: length * cos(angle) See left wheel side view swing arm length and angle calculations in BranchID 140, components 1 and 4 (in Side View Swing Arm Length and Angle. |
2 (Y): Right Wheel SVSA Fore/Aft Location | mm |
The longitudinal distance between the right wheel center and the right wheel center side view instant center or: length * cos(angle) See right wheel side view swing arm length and angle calculations in BranchID 140, components 2 and 5 (in Side View Swing Arm Length and Angle). |
3 (Z): Average SVSA Fore/Aft Location | mm | The mean of components 1 and 2. |
4 (RX): Left Wheel SVSA Vertical Location | mm |
The vertical distance between the left wheel center and the left wheel center side view instant center or: length * sin(angle) See left wheel side view swing arm length and angle calculations in BranchID 140, components 1 and 4 (in Side View Swing Arm Length and Angle). |
5 (RY): Right Wheel SVSA Vertical Location | mm |
The vertical distance between the right wheel center and the right wheel center side view instant center or: length * sin(angle) See right wheel side view swing arm length and angle calculations in BranchID 140, components 2 and 5 (in Side View Swing Arm Length and Angle). |
6 (RZ): Average SVSA Vertical Location | mm | The mean of components 4 and 5. |
