Wheel Center Translational Stiffnesses
Request Number: 50000050
Component | Unit | Comment |
1 (X): Left Wheel Center X Stiffness | N/mm | The left wheel center single wheel longitudinal stiffness
or: 1/C(1,1) |
2 (Y): Left Wheel Center Y Stiffness | N/mm | The left wheel center single wheel lateral stiffness
or: 1/C(2,2) |
3 (Z): Left Wheel Center Z Stiffness | N/mm | The left wheel center single wheel vertical stiffness
or: 1/C(3,3) |
4 (RX): Right Wheel Center X Stiffness | N/mm | The right wheel center single wheel longitudinal stiffness
or: 1/C(7,7) |
5 (RY): Right Wheel Center Y Stiffness | N/mm | The right wheel center single wheel lateral stiffness
or: 1/C(8,8) |
6 (RZ): Right Wheel Center Z Stiffness | N/mm | The right wheel center single wheel vertical stiffness
or: 1/C(9,9) |
