Wheel Rate, Ride Rate, and Hop Rate
Branch ID: 210
Request Number: 50000210
Table 1.
Component Unit Comment
1 (X): Left Wheel Rate N/mm The left wheel vertical stiffness (excluding tires) when both the left and right wheels are moving in-phase or:
1/(C(3,3)+C(3,9))
2 (Y): Left Ride Rate N/mm The left wheel vertical stiffness (tires in series) when both the left and right wheels are moving in-phase or:
((wheel rate)*(tire stiffness))/((wheel rate)+(tire stiffness))
3 (Z): Left Hop Rate N/mm The left wheel vertical stiffness (tires in parallel) when both the left and right wheels are moving in-phase or:
(wheel rate) + (tire stiffness)
4 (X): Right Wheel Rate N/mm The right wheel vertical stiffness (excluding tires) when both the left and right wheels are moving in-phase or:
1/(C(9,3)+C(9,9))
5 (Y): Right Ride Rate N/mm The right wheel vertical stiffness (tires in series) when both the left and right wheels are moving in-phase or:
6 (Z): Right Hop Rate N/mm The right wheel vertical stiffness (tires in parallel) when both the left and right wheels are moving in-phase or:
