Two-Wheeler MDL Library
The Two-Wheeler Library is installed as a part of the HyperWorks Desktop installation and can be accessed from the MotionView client.
Models can be modified interactively in MotionView to create topologies that are not supported in the default Two-Wheeler Library. The Two-Wheeler Library is open-source, ASCII-based, and can be modified by you.
- Telescopic - Classic: Rigid and Deformable Strut Rod
- Telescopic - Inverted: Rigid and Deformable Strut Rod
- Mono Shock
- Twin Shock
- Linear Torque Powertrain
- Sprocket-Chain Drive
The models and topology included in the Two-Wheeler Library are intended to be the beginning of the simulation process. The model built through the Assembly Wizard has geometry that properly illustrates the suspension of interest, but in some combinations, will not result in a good suspension design. You are responsible for populating the model with the appropriate suspension geometry, spring and shock absorber data, mass and CG location, bushing data, tire data, and other model information that is required to develop an accurate two-wheeler model.
