In this tutorial you will learn how to use the Load Export utility to bridge the gap between Multi-Body Dynamics (MBD)
analysis and Finite Element (FE) analysis in MotionView.
In this tutorial, you will learn how to convert results simulation run into file formats that can be used for fatigue
analysis (using a tool like NCode) and how to write a fatigue analysis file from the MotionView animation window.
MV-3030: Load Export
In this tutorial you will learn how to use the Load Export utility to bridge the gap between Multi-Body Dynamics (MBD) analysis and Finite Element (FE) analysis in MotionView.
MV-3040: Durability and Fatigue Tools
In this tutorial, you will learn how to convert results simulation run into file formats that can be used for fatigue analysis (using a tool like NCode) and how to write a fatigue analysis file from the MotionView animation window.
