getLinIterValues()
Return the "Linear Iterations" values.
Usage
linIterValues = adb.getLinIterValues( var, index = 0 )
- var (string) or (integer)
- The "Linear Iterations" variable name/index.
- index (integer)
- The "Linear Iterations" index.
Return Value
- linIterValues (array numarray)
- The "Linear Iterations" values
var must be a valid name or index
Index must have proper value.
linValues = adb.getLinIterValues( 1,2 )
