getType()
Get the type of the par value from the database.
Usage
parType = acs.getType( par, path )
- par (string)
- The parameter name.
- path (string)
- Data base path of the par.
Return Value
- parType (type int, str,...)
- The parameter value.
The parameter in the data base must be of a valid type.
The parameter must exist in the data base.
nodeNic = ROOT + RS + 'NODAL_INITIAL_CONDITION'
parType = acs.getType( par = "script", path = nodeNic )
