Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
This section on basics of fluid mechanics covers topics describing the fundamental concepts of fluid mechanics, such as
the concept of continuum, the governing equations of a fluid flow, definition of similitude and importance of non-dimensional
numbers, different types of flow models and boundary layer theory.
This section on turbulence covers the topics describing the physics of turbulence and turbulent flow. It also covers the
modeling of turbulence with brief descriptions of commonly used turbulence models.
This section on physics of turbulence introduces a brief history of turbulence and covers the theory behind turbulence
generation, turbulence transition and energy cascade in fluid flows.
The Reynolds number is not only used to characterize the flow patterns, such as laminar or turbulent flow, but also to
determine the dynamic similitude between two different flow cases.
The physics of turbulent flows have been discussed by presenting experimental observations and comparing it to laminar
flows. In this chapter, the focus will shift to the governing equations of these flow fields.
Turbulence is composed of turbulent eddies of different sizes. At high Reynolds numbers, a scale separation exists between
the largest eddies and smallest eddies.
This section covers the numerical modeling of turbulence by various turbulence models, near wall modeling and inlet turbulence
parameters specified for turbulence models.
This section on numerical approximation techniques covers topics, which describe the numerical modeling of the fluid flow
equations on a computational domain, such as spatial discretization using finite difference, finite element and finite volume
techniques, temporal discretization and solution methods.
This section on AcuSolve solver features covers the description of various solver features available in AcuSolve such as heat transfer, fluid structure interaction and turbulence modeling.
Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy
of AcuSolve results.
In 1883, Osborne Reynolds conducted an experiment where dye was injected into a glass
tube with water flowing due to gravity.
He studied the conditions of transition from laminar flow to turbulent flow, indicated by the
flow patterns in the tube. He analyzed that the flow patterns differed as the flow velocity
was changed. At low speed, the dye showed regular straight lines of a laminar flow pattern.
When the flow velocity increased, the dye became random (or chaotic) with eddies filling the
entire tube, and mixed with water. This random flow pattern is a turbulent flow. He further
noticed that the appearance of turbulent flow highly depended on a dimensionless parameter of
velocity and length scale, as well as viscosity. This parameter is now known as the Reynolds
number. Figure 1. The Dye Experiment Conducted by Osborne Reynolds
