udfGetFbdData()
Return data from a flexible body set.
fbdData = udfGetFbdData( udfHd, cmdName, dataName ) ;
AcuSolve User-Defined Function Global
udfHd
The opaque handle (pointer) which was passed to the user function.
cmdName (string)
Name of the FLEXIBLE_BODY command.
dataName (integer)
Symbolic name of the requested data.
UDF_FBD_PREV_DISPLACEMENT
Displacement at step n.
UDF_FBD_PREV_VELOCITY
Velocity at step n.
UDF_FBD_CURR_DISPLACEMENT
Displacement at step n+1.
UDF_FBD_CURR_VELOCITY
Velocity at step n+1.
UDF_FBD_INTERNAL_FORCE
Projection of fluid forces on the body.
UDF_FBD_EXTERNAL_FORCE
User-given external forces.
Return Value
fbdData (real)
Pointer to one dimensional real array of the requested data. The dimension of the array is num_modes (as given by the FLEXIBLE_BODY command) for all values of dataName.
This routine returns data from a flexible body model. For example,
char* name ; /* name of the UDF */
Integer i ; /* a running index */
Real* disp ; /* displacement (curr or prev) */
Real* dispC ; /* next displacement */
Real* vel ; /* velocity (curr or prev) */
Real* velC ; /* next velocity */
Real* extForce ; /* external force */
Real* intForce ; /* internal force */
name = udfGetName( udfHd ) ;
dispC = outVec ;
velC = outVec + nItems ;
/* If the first time step */
   if ( udfFirstStep(udfHd) ) {
      disp = udfGetFbdData( udfHd, name, UDF_FBD_CURR_DISPLACEMENT ) ;
      vel = udfGetFbdData( udfHd, name, UDF_FBD_CURR_VELOCITY ) ;
      for ( i = 0 ; i < nItems ; i++ ) {
          dispC[i] = disp[i] ;
          velC[i] = vel[i] ;
      return ;
/* Otherwise, get the data from the external program */
   intForce = udfGetFbdData( udfHd, name, UDF_FBD_INTERNAL_FORCE ) ;
   extForce = udfGetFbdData( udfHd, name, UDF_FBD_EXTERNAL_FORCE ) ;
   disp = udfGetFbdData( udfHd, name, UDF_FBD_PREV_DISPLACEMENT ) ;
   vel = udfGetFbdData( udfHd, name, UDF_FBD_PREV_VELOCITY ) ;
          dispC[i] = ... ;
          velC[i] = ... ;
  • This routine expects a valid udfHd.
  • cmdName must be a valid name.
  • dataName must be one of the values given above.
