udfPrintMess()
Print a message to the standard output, or .log file, if active.
udfPrintMess( udfHd, format, ... ) ;
AcuSolve User-Defined Function Basic
- udfHd
- The opaque handle (pointer) which was passed to the user function.
- format
- C printf() format.
- List of C variables.
Return Value
None
This routine prints a message to the standard output, or the .log file, if active. The argument list is the same as that of fprintf(, except that here udfHd takes the place of the file descriptor. For example,
String user_name ;
user_name = udfGetName( udfHd ) ;
udfPrintMess( udfHd, "user name is %s", user_name ) ;
This routine expects a valid udfHd.
