ACU-T: 6000 Static Mixer Simulation - AcuTrace
This tutorial provides the instructions for setting up, solving and viewing results for a simulation of a static mixer in combination with the post-processing module AcuTrace. In this simulation, AcuSolve is used to compute the species mixing within a simple mixer and AcuTrace is used to compute the particle motion of finite mass particles within the mixer. This tutorial is designed to introduce you to concepts necessary to visualize streamlines and produce particle path with AcuTrace.
- Generation of finite mass particle paths with AcuTrace.
- Conversion of the nodal output data with AcuTranstrace for reading into AcuFieldView.
- Post-processing the nodal output with AcuFieldView to visualize streamlines and particle path.
Prerequisites
You should have already run through the introductory tutorial, ACU-T: 2000 Turbulent Flow in a Mixing Elbow. It is assumed that you have some familiarity with AcuConsole, AcuSolve, and AcuFieldView. You will also need access to a licensed version of AcuSolve.
Prior to running through this tutorial, copy AcuConsole_tutorial_inputs.zip from <Altair_installation_directory>\hwcfdsolvers\acusolve\win64\model_files\tutorials\AcuSolve to a local directory. Extract StaticMixer.acs from AcuConsole_tutorial_inputs.zip.
Analyze the Problem
An important step in any CFD simulation is to examine the engineering problem and determine the important parameters that need to be provided to AcuSolve. Parameters can be based on geometrical elements (such as inlets, outlets, or walls) and on flow conditions (such as fluid properties, velocity, or whether the flow should be modeled as turbulent or as laminar).
The problem to be addressed in this tutorial is shown schematically in Figure 1. It consists of a mixing tube that contains several swept walls to instigate mixing within the tube. The inlet face is split into two regions, one containing 100 percent of species_1 and the other containing zero.
Figure 1. Schematic of the static mixer
The boundary condition at the inlet is defined to produce a fully developed inlet profile with velocity of 1.0 m/s. One portion of the inlet is defined to contain 100 percent of species_1, while the other inlet is defined to contain 0.0 percent of species_1.
The fluid in this problem is an epoxy resin, which has a density of 1264.0 kg/m3 and a viscosity of 1.49 kg/m-sec.
In addition to setting appropriate conditions for the simulation, it is important to utilize a mesh that will be sufficiently refined to provide good results. In this application, the flow will accelerate as it passes over the fin walls. This leads to the higher gradients that need finer resolution. Proper boundary layer parameters need to be set to keep the y+ near the wall surface to a reasonable level. Although a slightly refined mesh is used in this area, it should be noted that a proper mesh refinement study is necessary in order to determine the required mesh controls to obtain a grid independent solution. The mesh controls used in this tutorial are very coarse and are only intended to illustrate the process of setting up the model and to retain a reasonable run time. A significantly higher mesh density is needed to achieve a grid converged solution.
Define the Simulation Parameters
Start AcuConsole and Create the Simulation Database
In the next steps you will start AcuConsole, and open the database for storage of the simulation settings. In this tutorial, you will begin by loading the existing database, preparing the particle trace settings and running the model. Next you run AcuTrace to generate the particle paths within the flow field and convert the data for reading into AcuConsole. Finally, you will visualize some characteristics of the results using AcuConsole.
- Start AcuConsole from the Windows Start menu by clicking .
- Click the File menu, then click Open to open the Chose a file dialog.
- Browse to the directory where StaticMixer.acs is stored.
- Select StaticMixer.acs and then click Open to open the database.
Set General Simulation Parameters
In next steps you will review parameters that apply globally to the simulation. To make this simple, the basic settings applicable for any simulation can be filtered using the BAS filter in the Data Tree Manager. This filter enables display of only a small subset of the available items in the Data Tree and makes navigation of the entries easier.
The general parameters that you will set for this tutorial are for turbulent flow, steady analysis, and mesh type as fixed.
Set Solution Strategy Parameters
Set Material Model Parameters
Prepare Output Data Stream
In order to utilize the finite mass particle trace functionality for particles that have non-constant density, you are required to store additional variables during the simulation. This is done by using the Derived Quantity Output mechanism.
- In the Data Tree, double-click Output to expand it.
- Double-click Nodal Output.
- Change the Time step frequency to 1000.
- Set the Time frequency to 0.
- In the Data Tree, double-click Derived Quantity Output to open the Derived Quantity Output detail panel.
Compute the Solution and Review the Results
Run AcuSolve
In the next steps you will launch AcuSolve to compute the solution for this case.
Monitor the Solution with AcuProbe
AcuProbe can be used to monitor residuals.
Prepare Particle Trace Attribute for AcuTrace
Now that the steady-state simulation is complete, you can use the finite mass particle tracer to simulate micro-particles of SiO2, which are often used to add strength to the epoxy.
Define Particle Trace Parameters for Static Analysis
In the next steps you will define the particle trace data.
Define Finite Mass Boundary Conditions
In the next steps you will set the finite mass boundary conditions.
Define Particle Seeds
In the next steps you will define the particle seeds that are moving into the flow regime.
Define the Output Parameters
In the next steps you will define the output parameters.
Compute the Particle Paths and Review
Now that the steady-state simulation is complete, we can use the finite mass particle tracer to simulate micro-particles of SiO2 which are often used to add strength to the epoxy.
Run AcuTrace
In the next steps, you will launch AcuTrace to compute the solution for this case.
Convert Results for AcuFieldView
Once the run is complete, you need to convert the results so that they can be read in AcuFieldView. To do this, run the AcuTransTrace utility. This tool can be used to convert data for Ensight, FieldView or AcuDisplay.
Post-Process with AcuFieldView
- How to find the data readers in the File pull-down on the Main menu and open up the desired reader panel for data input.
- How to find the visualization panels either from the Side toolbar or the Visualization panel pull-downs on the Main menu to create and modify surfaces in AcuFieldView.
- How to move the data around the modeling window using mouse actions to translate, rotate and zoom in to the data.
Figure 17.
Create a Boundary Surface and Coordinate Plane in Mixer
- In the Boundary Surfaces dialog, change the Coloring to Geometric.
- Select grey from the color tab.
- Uncheck the Show Mesh option to turn off the mesh display.
- From the Boundary Types list, select OSF: Fin Walls and click Ok.
- Orient the geometry to show that the flow moves from bottom to top of the screen.
- In the Boundary Surfaces dialog, click Create to create a new boundary surface.
- From the Boundary Types list, select OSF: Pipe Walls and click OK.
- Set the Display Type to Outlines and set Coloring to Geometric.
Set the Coordinate Surface Showing Velocity Magnitude on the Mid Coordinate Surface
Set the Boundary Surface and Particle Paths
Summary
In this tutorial, you successfully set up and solved for a steady simulation of a static mixer to visualize the particle path. You started the tutorial by opening a database in AcuConsole and setting up the simulation parameters to compute the species mixing within the mixer. You ran AcuTrace to generate the particle paths within the static mixer and converted the data using AcuTranstrace to visualize the particle paths in AcuFieldView.
