The Solver result comparison HV versions tab ensures that HyperView does not deprecate any result information after
post-processing.
- Any combination of results from different data types, simulation and subcases
are exported for each HyperView version and
compared.
- Any difference would trigger the problem and would be reported.
Different levels of verification and validation include:
- Verification of the reference result files across two versions of HyperView (with the same solver version results).
Click the Manufacturing Solution tab then click .
From the Solver drop-down menu, select a solver whose results are to be
compared.
Select a Tolerance method then input the value used to set the tolerance for
the difference in values between the reference and current version result files
during comparison.
Option |
Description |
Default |
1e-6 for Scalar, Tensor, and Vector, if not individually
chosen. |
Scalar |
Enter values if different for the scalar result type. |
Vector |
Enter values if different for the vector result type. |
Tensor |
Enter values if different for the tensor result type. |
Click Apply to set new values.
Choose between a PowerPoint or
HTML report of the result value comparison.
- Pass
- This returns a detailed report containing one slide per data type
across load cases.
- Fail
- In case of a failure, one slide per load case for each datatype is
published so that it is easy to identify the load case that contains
a difference in values.
Select the current and reference solver
version.
Select a HyperView model file.
Select a HyperView result file.
Select an output directory.
Click Apply to store your results information.
Select any combination of subcases, simulations, and result types from the
populated areas.
Click All to select all items listed.
Click Apply to generate data to compare the results of
the chosen combination.
The Compare result section displays the current file
and the corresponding reference file. Click Report to
display the diff report detailing the differences between files.
Tip:
- Click Messages to view any
error messages.
- Click Html
Report to generate an HTML report of your
session information for any number of files run through the
process.
