Process Studio
Process Studio is a process authoring tool that allows you to create a process template (.pmt) with customized controls for use in Process Manager.
The user interface for each task in a process, also known as an HWPM Page, is created by dragging and dropping HWPM Controls and "stitching" them together. The process tree can also be created interactively, and each task can be associated with an HWPM Page. Each task can be associated with a Tcl module also, if an already programmed module exists. Programmers can add to the suite of available HWPM Controls by writing Java Beans.
