Create the Process Tree
Switch to the Process view tab.
A single folder will be displayed in the panel. The name of the folder can be changed to represent the process being authored. Individual tasks and folders can be added to the main process folder. If additional folders are added to the process, tasks can be added to each of the new folders.
Right-click on the Process folder and select
Add Task.
The the right-click context menu can also be used to delete tasks and folders and change the completion order of tasks.
In the Property view, set the Name and Label to Import
IGES.
Note: Editing the name will automatically edit the label for the first time. Also, an underscore will be automatically added to names separated with spaces.
- Select HWPM Page for the Task Type.
- Select tutorial_Page1 for the HWPM Page.
- Click Apply.
- Create another task with Name and Label set to Mesh.
- Select tutorial_Page2 for the HWPM Page.
- Click Apply.
