Dockable Panels
You can dock/undock task panels by enabling or disabling the checkbox in the Property view panel.
By default, Dockable is enabled (checked). If you leave this box checked, the Page View panel will allow you to move the panel to suit your needs.
Each page, by default, will have the icon for Dock/Undock on the top right-hand corner. This icon is responsible for docking and undocking as shown below.
Modify an Old Template
To modify an old template, if it is a HWPM page type, use the Icon control, as shown below. This icon is responsible for marking the task Dock/Undock.
Figure 3.
