Process Manager Commands
-a<>
Creates a new "application" type of process template.
-a<filename>
No space between -a and <filename>
Arguments
- Filename
- Name of application template file to be created.
-Ddebug
Displays the debug window.
-Ddebug
Arguments
- -Ddebug=<true/false>
- True if debug should be displayed.
-h
Displays the command line options.
-h
Arguments
None
-n<>
Creates a new "todo" type of process template.
-n<filename>
No space between –n and <filename>
Arguments
- Filename
- Name of todo template file to be created.
-o<>
Opens the given process template file.
-o<filename>
No space between -o and <filename>
Arguments
- Filename
- Name of template file to be opened.
