Execute/Run the Process
- Launch HyperMesh and select Process Manager from the Applications menu.
- Once Process Manager is open, click the Open icon and search for your .pmt project.
- Save the process instance.
- Continue with the next set of section in the template, or go to the next task.
- Close the instance and reopen the previously saved instance.
