Set Up Template Preferences
- From the menu bar, select Tools > Template Preferences.
- In the Template Preferences tab, you can give the process a title (user-friendly name).
In the About Dialog tab, you can specify the text to appear in the about box
(as an HTML string).
Figure 1. - Save the file by selecting Save from the File menu.
