Use Tcl Script to Write Callbacks
To access/modify properties of a TextField (or TextArea) whose instance name is mytext:
Property (Type) | Getter/Setter | Example |
value | Getter | set strValue [::hw::pmgr::PmgrGetData 0 "mytext.value"]; |
Setter | set strValue "ABC"; ::hw::pmgr::PmgrSetData 0 "mytext.value" $strValue; |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "mytext.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mytext.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "mytext.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mytext.visible" true; |
To access/modify properties of a Button whose instance name is mybutton:
text | Getter | set strText [::hw::pmgr::PmgrGetData 0 "mybutton.text"]; |
Setter | set strText "Import Model"; ::hw::pmgr::PmgrSetData 0 "mybutton.text" $strText; |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "mybutton.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mybutton.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "mybutton.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mybutton.visible" true; |
To access/modify properties of a FileBrowser whose instance name is myfb:
value | Getter | set strFilename [::hw::pmgr::PmgrGetData 0 "myfb.value"]; |
Setter | set strFilename
"C:/altair/hw8.0/demos/hm/bumper.hm"; ::hw::pmgr::PmgrSetData 0 "myfb.value" $ strFilename; |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "myfb.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "myfb.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "myfb.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "myfb.visible" true; |
To access/modify properties of a ComboBox whose instance name is mycombo:
value | Getter | set strSelected [::hw::pmgr::PmgrGetData 0 "mycombo.value"]; |
Setter | set strSelected "Nastran"; ::hw::pmgr::PmgrSetData 0 "mycombo.value" $ strSelected; |
entries | Getter | set listEntries = [::hw::pmgr::PmgrGetData 0
"mycombo.entries"]; for {set nIdx 0} {$nIdx<[llength $listEntries]} {incr nIdx} { set strEntry [lindex $listEntries $nIdx]; }; |
Setter | set listEntries "Red {Green Color}
Blue"; ::hw::pmgr::PmgrSetData 0 "mycombo.entries" $ listEntries; |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "mycombo.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mycombo.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "mycombo.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mycombo.visible" true; |
To access/modify properties of a ListBox whose instance name is mylist:
value | Getter | set listSelected = [::hw::pmgr::PmgrGetData 0
"mylist.value"]; set strFirstSelected [lindex $listSelected 0]; |
Setter | set listSelected "{LS Dyna} Abaqus"; ::hw::pmgr::PmgrSetData 0 "mylist.entries" $ listSelected; |
"mylist.entries"]; for {set nIdx 0} {$nIdx<[llength $listEntries]} {incr nIdx} { set strEntry [lindex $listEntries $nIdx]; }; |
Blue"; ::hw::pmgr::PmgrSetData 0 "mylist.entries" $ listEntries; |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "mylist.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mylist.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "mylist.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mylist.visible" true; |
To access/modify properties of a RadioButton whose instance name is myradio:
value | Getter | set strValue [::hw::pmgr::PmgrGetData 0 "myradio.value"]; |
Setter | set strValue "Nastran"; ::hw::pmgr::PmgrSetData 0 "myradio.value" $strValue; |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "myradio.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "myradio.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "myradio.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "myradio.visible" true; |
To access/modify properties of a CheckBox whose instance name is mycheckbox:
value | Getter | set Selected [::hw::pmgr::PmgrGetData 0 "mycheckbox.value"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mycheckbox.value" true; | |
enable (true/false) | Getter | set bEnabled [::hw::pmgr::PmgrGetData 0 "mycheckbox.enable"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mycheckbox.enable" true; | |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "mycheckbox.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mycheckbox.visible" true; |
To access/modify properties of a Label whose instance name is mylabel:
value | Getter | set strValue [::hw::pmgr::PmgrGetData 0 "mylabel.value"]; |
Setter | set strValue "Import Model: "; ::hw::pmgr::PmgrSetData 0 "mylabel.value" $strValue; |
visible (true/false) | Getter | set bVisible [::hw::pmgr::PmgrGetData 0 "mylabel.visible"]; |
Setter | ::hw::pmgr::PmgrSetData 0 "mylabel.visible" true; |
To send any message (command/query) to HyperWorks:
Example | |
Prepare Message | -- |
Send Message | *readfile $filename; |
- Example 1
- To get the selected file from the file browser (myfb) and set it on the
text field (mytext), the following callback script will be written on
the myfb’s OnClicked:
var filename = DataModel.GetValue("myfb");
DataModel.SetValue("mytext", filename);
- Example 2
- To get the HyperMesh file name from the text
field (mytext) and send the command to HyperMesh to read the HyperMesh file, the following callback script
will be written on the Apply button’s OnClicked:
var filename = DataModel.GetValue("mytext");
var command = "*readfile " + filename;
HyperWorks.SendMessage(command);
}; ## This semi colon is also VERY important.
To access/modify properties of a Slider whose instance name is mySlider:
Current Slider Value | Getter | set nCurr_val [::hw::pmgr::PmgrGetData 0 "mySlider.value"]; |
Setter | set nCurr_val 20; ::hw::pmgr::PmgrSetData 0 "mySlider.value" $nCurr_val; |
Orientation (Vertical / Horizontal ) | Getter | set strSlider_orientation [::hw::pmgr::PmgrGetData 0 "mySlider.orientation"]; |
Setter | set strSlider_orientation "Vertical"; ::hw::pmgr::PmgrSetData 0 "mySlider.orientation" $ strSlider_orientation; |
Slider Intervals | Getter | set nSlider_interval [::hw::pmgr::PmgrGetData 0 "mySlider.tick_intervals"]; |
Setter | set nSlider_interval 20; ::hw::pmgr::PmgrSetData 0 "mySlider.tick_intervals" $nSlider_interval; |
Slider Max | Getter | set nSlider_max [::hw::pmgr::PmgrGetData 0 "mySlider.ticks_RangeMax"]; |
Setter | set nSlider_max 200; ::hw::pmgr::PmgrSetData 0 "mySlider.ticks_RangeMax" $nSlider_max; |
Slider Min | Getter | set nSlider_min [::hw::pmgr::PmgrGetData 0 "mySlider.ticks_RangeMin"]; |
Setter | set nSlider_min 20; ::hw::pmgr::PmgrSetData 0 "mySlider.ticks_RangeMin" $nSlider_min; |
Ticks Label Visibility (True/False) | Getter | set strSlider_ticks_label [::hw::pmgr::PmgrGetData 0 "mySlider.ticks_label"]; |
Setter | set strSlider_ticks_label "False"; ::hw::pmgr::PmgrSetData 0 "mySlider.ticks_label" $strSlider_ticks_label; |
Tooltip | Getter | set strSlider_tooltip [::hw::pmgr::PmgrGetData 0 "mySlider.tooltip"]; |
Setter | set strSlider_tooltip "This is Slider"; ::hw::pmgr::PmgrSetData 0 "mySlider.tooltip" $strSlider_tooltip; |
Visible (true/false) | Getter | set bSlider_visible [::hw::pmgr::PmgrGetData 0 "mySlider.visible"]; |
Setter | set bSlider_visible true; ::hw::pmgr::PmgrSetData 0 "mySlider.visible" $bSlider_visible; |
To access/modify properties of a Spinner whose instance name is mySpinner:
Current Slider Value | Getter | set nSpinner_curr_val [::hw::pmgr::PmgrGetData 0 "mySpinner.value"]; |
Setter | set nSpinner_curr_val 10; ::hw::pmgr::PmgrSetData 0 "mySpinner.value" $nSpinner_curr_val; |
Maximum Value | Getter | set nSpinner_max [::hw::pmgr::PmgrGetData 0 "mySpinner.maxspinnervalue"]; |
Setter | set nSpinner_max 100; ::hw::pmgr::PmgrSetData 0 "mySpinner.maxspinnervalue" $nSpinner_max; |
Minimum Value | Getter | set nSpinner_min [::hw::pmgr::PmgrGetData 0 "mySpinner.minspinnervalue"]; |
Setter | set nSpinner_min 1; ::hw::pmgr::PmgrSetData 0 "mySpinner.minspinnervalue" $nSpinner_min; |
Step Size Value | Getter | set nSpinner_step_size [::hw::pmgr::PmgrGetData 0 "mySpinner.stepsizevalue"]; |
Setter | set nSpinner_step_size 5; ::hw::pmgr::PmgrSetData 0 "mySpinner.stepsizevalue" $nSpinner_step_size; |
Tooltip | Getter | set strSpinner_tooltip [::hw::pmgr::PmgrGetData 0 "mySpinner.tooltip"]; |
Setter | set strSpinner_tooltip "This is
Spinner"; ::hw::pmgr::PmgrSetData 0 "mySpinner.tooltip" $strSpinner_tooltip; |
Visible (true/false) | Getter | set bSpinner_visible [::hw::pmgr::PmgrGetData 0 "mySpinner.visible"]; |
Setter | set bSpinner_visible true; ::hw::pmgr::PmgrSetData 0 "mySpinner.visible" $bSpinner_visible; |
