Workflow
The Workflow Manager serves as a handle to the workflow. With the handle to the Workflow, the beans can switch to the next task, previous task, or to any specific task.
IHWMWorkflow hwmWorkflow = this.GetFrameWork().GetWorkflow();
* The main function wherein, something will be done when the
* button is pressed
public void DoSomething()
try
hwmWorkflow.NextTask();
catch (Exception exception)
exception.printStackTrace();
Some of the methods exposed by the IHWMWorkflow interface include:
- NextTask()
- Go to the next task.
- PrevTask()
- Go to the previous task.
- GotoTask(String strTaskPath)
- Go to the task with given path.
- GotoTaskByName(String strTaskName)
- Go to the task with given name.
- SetCurrentTaskState(int nState)
- Set current task state.
