This manual provides a detailed list and usage information regarding command statements, model statements, functions and
the Subroutine Interface available in MotionSolve.
AeroDyn Libraries MotionSolve supports the AeroDyn libraries for aero-elastic analysis of wind turbines.
Co-simulation Introduction
Co-simulation is a simulation methodology that allows complex systems comprised of subsystems to be easily simulated.
Co-simulating Using TCP/IP
Inter-Process Communication (IPC) co-simulation allows co-simulation to run on the same machine, as well as between different machines/platforms.
