Modeling Mechanical Systems
A mechanical system can be thought of as being composed of a set of basic mechanical entities that interact with each
other by exchanging energy or information in well-defined ways. For example, a simple pendulum system is composed
of a rigid body connected to the ground by a revolute joint. MotionSolve provides physics-based, mathematical models of such entities and ways to assemble them into realistic models of
complex mechanical systems. It then lets you simulate your models to gain insight into their behavior.
