Utility/Data Access
SubroutineReturns the mass, c.g., and inertia tensor for a body or the entire model.
Use
The function can be called by CONSUB, REQSUB,
SENSUB or SEVSUB.
- Fortran Calling Syntax
- CALL BODY_MASS_PROPERTY(type, id, cm, mass, ip)
- C/C++ Calling Syntax
- c_body_mass_property(type, id, cm, mass, ip)
- Python Calling Syntax
- [cm, mass, ip] = py_body_mass_property(type, id)
- MATLAB Calling Syntax
- [cm, mass, ip] = m_body_mass_property(type, id)
Attributes
- type
- [string]
- Select from Part, Point_Mass, Flex_Body or
Model. These keywords are case-insensitive.
Note: For type Model, MotionSolve
calculates the cm, mass and
ip of the entire MBD model.
- id
- [integer]
- Specifies the ID of the element of type specified above.
Output
- cm
- [double precision]
- A double precision array of length three containing the x, y, and z
coordinates of the requested element expressed in the global frame.
- mass
- A double precision array containing the mass of the requested element
ip
- A double precision array of length six containing the six inertia tensors
(Ixx, Iyy, Izz, Ixy, Ixz, Iyz) for the requested element expressed in global
frame.
