CHEBY
The Cheby function evaluates a Chebyshev polynomial at a specific value .
Arguments
- The independent variable. For example, to specify time as the independent variable, specify as TIME.
- The phase shift in the Chebychev polynomial.
- The coefficients in the Chebychev polynomial. Specify only as many coefficients as needed with a maximum of 31 coefficients.
Definition
<Force_Vector_TwoBody
id = "30101"
type = "ForceOnly"
i_marker_id = "30102031"
j_floating_marker_id = "30101031"
ref_marker_id = "30101010"
fx_expression = BISTOP(DX(30102030,30101010,30101010),
VX(30102030,30101010,30101010),0.5,9.5,10000000,2.1,1,0.001)"
fy_expression = "0"
fz_expression = "0"
