Adhesion Model and Single Phase Surface Tension
Both single phase surface tension and adhesion modeling is based on the work of Akinci et al.
Both models are capable of reproducing qualitatively realistic results, but are in principle unphysical and cannot be generalized for an arbitrary case/simulation. Because of this, trial-and-error tuning of the surface tension coefficient and the adhesion coefficient is necessary if realistic fluid behavior is to be achieved.
Both adhesion and single phase surface tension models rely on a form inter-particle force, which binds the particles together. The way the force is modeled is through a specific kernel shape which mimics a potential energy well. In that sense, particles tend to keep a certain distance from each other and introduce elastic forcing if the particles get too close or too far from each other.
- Indicies and
- Stand for adhesion and cohesion.
- Is the appropriate kernel used for each of the forces.
- Is the mass of the particle.
- Is the distance between two interacting particles.
- and
- Are instantaneous particle densities.
- Is the default density value of the particle phase.
- Is the adhesion coefficient.
- Is the cohesion or surface tension coefficient.
The adhesion model can be used in conjunction with the more physical multiphase surface tension model. In that situation, the surface tension forces are physical and only the adhesion model is left to be tuned, which can be a significantly easier exercise.
