The purpose of this tutorial is to demonstrate how to carry out Fluid-Structure Interaction analysis that is, with
OptiStruct nonlinear transient analysis coupling within AcuSolve fluid dynamic analysis.
The purpose of this tutorial is to demonstrate how to carry out a Thermal Fluid-Structure Interaction analysis on
an engine exhaust manifold with conjugate heat transfer and structural deformation.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
