This manual presents solved verification models including NAFEMS problems.
View new features for OptiStruct 2020.
OptiStruct® is an industry proven, modern structural analysis solver for linear and nonlinear structural problems under static and dynamic loadings.
Discover OptiStruct functionality with interactive tutorials.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
Required model files for the models you build.
Calculates the transmission loss using Finite Element Method in OptiStruct.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
The HyperWorks Solver Run Manager is a unified utility that allows the user to start different HyperWorks Solvers.
