The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
Examines the Hyperelastic behavior of a Hexahedral element under enforced displacement using different material models
such as Arruda Boyce, Reduced polynomial, Yeoh and Ogden model.
In this problem, a rubber disk which is pinned at its circumferential edge is subjected to pressure load. This causes
the disk to bulge into a spherical shape, like a balloon.
OS-V: 0800 Hyperelastic Material Verification
Examines the Hyperelastic behavior of a Hexahedral element under enforced displacement using different material models such as Arruda Boyce, Reduced polynomial, Yeoh and Ogden model.
