OS-T: 1910 Dynamic Analysis of a Slider Crank with Flexible Connecting Rod
In this tutorial you will work with a slider crank model, which consists of a rigid crank, a flexible connecting rod,
and a rigid sliding block. The objective of this analysis is to determine the deformation and stress of a flexible
connecting rod under the high speed motion of the system.
