CQPSTN
Bulk Data Entry Defines a plane strain quadrilateral element in x-z or x-y plane.
CQPSTN | EID | PID | G1 | G2 | G3 | G4 | G5 | G6 | |
G7 | G8 | THETA |
CQPSTN | 111 | 2 | 31 | 74 | 75 | 32 | 51 | 52 | |
53 | 85 | 15.0 |
EID | Unique element
PID | A
PPLANE entry identification
number. Default = EID (Integer > 0) |
G1, G2, G3, G4 | Identification numbers
of connected corner grid points. These fields are mandatory. No default (Integers > 0, all unique) |
G5, G6, G7, G8 | Identification numbers
of connected edge grid points. Default = blank (Integers > 0 or blank) |
THETA | Material orientation angle in
degrees. Default = 0.0 (Real) |
- Element identification numbers must be unique with respect to all other element identification numbers.
- The Grid ordering of
G1 through G8 are defined as:
Figure 1. CQPSTN Definition - The continuation line is optional.
- If the PPLANE entry referenced in field 3 references a MAT3 entry, material properties and stresses are always given in the xm-zm coordinate system shown in Figure 1.
- Plane strain analysis defined in x-y plane is supported, i.e. the axis labels of “z” above can be replaced by “y”.
- A concentrated load (e.g. a load
specified by a FORCE entry) at a grid
Gi of this element is defined to distribute along the
thickness, T, of the element. For example, in order to apply a load of 200
N/m to a node Gi with the element thickness being 5.0m,
the amount to be specified on the load entry should be:
(1) The default thickness of 1.0 is used, if T is not specified on the PPLANE entry.
- Plane strain elements are supported in linear analysis, small and large displacement nonlinear static analyses. They are currently not supported for large displacement inertia relief analysis.
